Weldon's avatar
Weldon
Slides slow to come in
My 2 slides are slow coming in. Battery checked 13.3 volts I then disconnected the positive cable and it still checked 13.3. Other than proper lubrication for moving parts under the slide and the rubber gaskets what else might i check? Plenty of fluid, actually just a slight overfill.
If it is the pump does it perform like this ort does it just stop working? Thanks for comments.
  • Follow up...the battery is good. Had a ground wire that I did tighten about a quarter turn and checked other connections. Slides do work but am going to improve existing ground wires.
  • I have a new battery but will check the battery under load to see what voltage is then.If it is 13.3 without a load what would the drop likely be under load?
    Can the pump/motor be repaired if it comes to that...meaning rebuilt.
  • If there's a question about the batteries, start the generator. If the batteries are the problem, the large charging current from the generator to the batteries will at the same time put the large current into the slides.
    So, if the slides work a lot better with the generator running, then the batteries are a problem. If the generator doesn't make a difference, it's probably not a battery problem. This is a lot easier than pulling the batteries and having them tested.
    Bill
  • Check your battery voltage while the slide is moving. I'll bet that the voltage drops which tells me the battery is going bad. If the voltage does not drop under load then there is something like a loose wire or corrosion of a wire or something mechanical with the slides.
  • Get the battery checked out. I'm guessing the battery might be bad under load.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
