myredracer
Oct 15, 2017Explorer II
A photo might help if you can.
I'd go to Home Depot and buy a cinch clamp crimper which sometimes come with a few clamps. Last time I saw them at HD they were like around $35. That way you can use what's typically used at the factories. If there's a PEX fitting (not as part of the pump), you might replace it with a brass PEX fitting, also available at HD. It can't hurt to have a cinch clamp crimper and some clamps in your toolbox in your RV. Never know when you might need it. Do NOT use a gear clamp on the plumbing fittings.
Some have replaced that hose with braided stainless steel hose along with the appropriate PEX fittings.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
