MEXICOWANDERER
Dec 29, 2017Explorer
AMAZON
Leviton 8300-GY 20 Amp, 125 Volt, Extra Heavy Duty Hospital Grade, Duplex Receptacle, Straight Blade, Self Grounding, Gray
4.5 out of 5 stars 3 customer reviews
Price: $8.02 FREE Shipping for Prime members
eBray
Overview
If you are building your own audiophile power cords to improve component performance, you'll find the WattGate 381 receptacle essential. Quality of construction is top-notch, featuring glass-filled nylon front and rear housings. Mounting strap, rivets and grounding strip are gold-plated brass for the ultimate in corrosion resistance and power transfer. Installation of the 381 is simple and efficient due to rear wiring and large, #10 brass terminal screws. Terminal clamps are gold plated, solid brass and shaped to better grip the conductors. A triple-wiper design allows the plug blades to be gripped at three separate points.
Additionally, the heavy-duty contacts maximize the clamping spring-rate and ensure conductivity. All plating is accomplished through a three-part process: oxygen free copper plating, electrolysis nickel, and finally 24k gold plating. Receptacle contacts are cryogenically treated.
Receptacle is rated at 125 VAC, 20A.
Highlights
Cryogenic heat treat hardened contacts
Solid brass contact construction
Three step 24k gold plating process
ONLY! ONE HUNDRED FORTY EIGHT DOLLARS
eBray
Overview
Highlights
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
