BFL13's avatar
BFL13
Explorer II
Apr 03, 2015
Small Fridge on Inverter for TC-1.7 vs 3.2 cuft Report
Ran an inverter test comparing two small fridges to replace the old 3-way in the 1981 TC. There have been several threads on using 120v fridges on inverter, so this adds something to the data base.
( The 3.2 is the size we want to fill the hole where the old fridge was and the 1.7 is way too small, but had them both before returning the 1.7 so tested it while in hand :) )
Both fridges were tested at 1/2 cold setting on dial.
A. Danby 1.7 cuft model DCR017A2WDB-- back label says 115v/1.3a (AC)
Tested on 2000w Vector MSW inverter (as mounted in the TC)--it ran the fridge ok.
Switched to 1000w Xantrex PSW inverter in 5er where the Trimetric can show the draw. Fridge ran ok.
Start-up draw jump to 20a (DC) then quickly fell off to 8.5a then after a minute settled at 7.6a. After three minutes it shut off --assume fridge at set temp, didn't check that.
No test of cycling times to maintain temp was done.
B. Igloo 3.2 cuft model FR320--back label says 115v/0.8a (AC)
Tested on 2000w Vector MSW inverter in TC--it ran the fridge ok.
On 1000w PSW inverter in 5er, ran ok.
Start-up draw jump to 30a (DC) then immediately dropped to 4.0a then back up to 4.3/4.4a and held there for ten minutes and shut "off", holding at 0.2a -- didn't check its temperature.
No test of cycling times done.
Interesting how the Igloo is almost twice the size but draws much fewer DC amps. The daily AH draw is another thing of course where they might cycle differently.
The two fridges are in this link if anybody is curious:
http://www.londondrugs.com/Refrigerators/appliances-kitchen-refrigerators,default,sc.html
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
