westend
Oct 17, 2016Explorer
Trackrig wrote:westend wrote:
Depending on ambient temps and if you use the optional temperature compensation sensor, you may wish to keep an eye on your batteries when that controller is in float stage. Nominal 13.6V float will percolate some batteries.
I plan on using Costco batteries as they're right down the street. I do plan on using the temperature compensater.
Bill
That will work well. I charge 2 x 6V Energizers with the solar set at 13.6V float w/temp comp. I'm in MN so the Winter and Summer float voltage swings by .5V or so.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
