This must be an easy fix but I am at a lost. Pulled our 2016 Navion Itasca out of storage to load up for our trip to Colorado and the smoke alarm is beeping every 20 seconds or so. I have replaced...
Have you checked the voltage on the HARDWIRED battery wires at the detector. If you have LOST the 12 volts to the Detector, the beeping may indicate THAT and not the low power of a 9 volt battery when you have a 9 volt Battery ONLY detector. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
