Boddhisattvha's avatar
Jan 12, 2013
So FED UP with Propane. Advice Please
I have had it with this ridiculous nonsense. We have a 19ft trailer we use very often. EVERY NIGHT the propane system shuts off. I've been reading on this problem for a couple weeks now and it really doesn't seem like it gets cold enough here for this to be happening.
We live in California and the coldest it has gotten here is 28F on ONE night. An average night is between 30-40F. Everything I have read talks about using propane in -20F temps and at THAT point having problems. The water heater and stove work just fine until dark and it starts getting cold.
I have 20# tanks and have tried topping them off. Didn't do jack.
At this point I'm ready to take a match to the whole damn trailer.
Before I make my own special smores I was wondering what else could be causing this?
I'm thinking maybe the propane regulator could be bad? But if so it worked perfectly fine through Summer and Fall and didn't give me problems until it got cold. Can someone recommend a good cold weather regulator?
Any advice is appreciated.
  • When you say it shuts off is it early in the night or near morning? How are your batteries?
  • There could be water in your LP pipes. You could take loose next to the regulator and then at water heater, use an air compressor to blow them out good.
    If you are going to replace the regulator, get an auto transfer type. They are a little more convient and uses only one tank at a time.
  • where did you buy your propane ?
    have you emptied the tanks and let them air out dry
    could they have moisture or OIL in them
    have you taken the regulator to a certified 'gas' service man to be checked cleaned or replaced
    AFAIK there is NO special regulator, unless you are talking "Artic" weather and Compressed natural gas
  • Certainly should not need any special type of regulator at those temps...maybe just a new standard regulator that you could return if problem not solved by cheapest route...
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
