full_mosey
Aug 23, 2013Explorer
I have two AGM/solar systems.
I recently starting watching morning volts by looking for a declining Voltage daily trend. If the 12V fridges are running, I note the overnight low Volts as well(a feature of the Turnigy meter).
I also MAY note if the transition from ABS to float is later each day. I don't sit around staring at the controllers!
This method works because I rely on solar for Absorb and float. With solar, the batteries get no charging overnight. Therefore, there are no surface charges to foul up Volt readings.
When morning Volts are low, out comes the genny to power 120V chargers to bulk up the batteries. These batteries were not always treated this well.
In short, a glance at a meter tells me if I need to deploy the genny. It takes longer to explain.
I will know to replace the batteries, due to low capacity, when the genny run does not result in a higher low Voltage the following morning.
I have dry-camped as many as 31 consecutive days before and plan 42 days in Quartzite in Jan-Feb next year with these batteries. The batteries will be 4 and 5 years old at the beginning of the trip.
Am I doing it wrong?
HTH;
John
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
