time2roll
Jun 23, 2015Nomad
Joel_T wrote:Given your criteria I recommend minimum #6 wire and a 50 amp fuse. Fuse to be close to the B+ terminal.
So, if I have a 30amp controller running 2 160watt panels what size circuit breaker fuses will work between controller and battery....30a....50a? (Besides a 40a that is, that are backordered a month and a half.)
Maxi fuse holder #6 wire and up to 60 amp.
Bussmann CB185-50 circuit breaker Switchable
If the run is short, protected and in plain view I might just skip the fuse.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
