Slownsy's avatar
Slownsy
solar + batteris
Hi all.
I am in proses of installing solar on my FW I planed on installing 2
/150W panels but made mistake when ordering and ordered 2 lots of 2 so have got 4/150W panels, also got 30' of 8AVG cable to split to my trimetric sc 2030 controller and 2030 monitor. cable is rated for 600v so is this a little to small or will it be ok. Al panels max 36A at 16' to controller .7219v drop or 4.0108% drop.2 260A 6V Crown Batteries what are your thoughts.
Frank.
  • Hi westend,
    No. The trimetric sc 2030 is a 30 amp pwm device intended for nominally 12 volt panels.
    westend wrote:
    Will that controller handle 150 VDC?
  • Hi,
    I think he means 150 watt panels, but it is unclear that this is the case. The voltage on the panels is also a quandary.
    If it is 600 watts in total a 30 amp charge controller is not going to cut it. He will need at least a 45 amp or better yet a 60 amp controller.
  • Slownsy wrote:
    Hi all.
    /150v panels but made mistake when ordering and ordered 2 lots of 2 so have got 4/150v panels, also got 30' of 8AVG cable to split to my trimetric sc 2030 controller and 2030 monitor. cable is rated for 600v so is this a little to small or will it be ok. At panels max 36A !6' to controller .7219v drop or 4.0108% drop.2 260A 6V Crown Batteries what are your thoughts.
    Frank.
    Are these panels 150 volt panels? If so they will NOT work with the SC2030 solar charge controller. If there 150 Watt 12 volt panels then they will work. I would recomend using only three panels as 4 will cause it to clip anything over 31 amps and cause the controller to heat up. Do not allow the controller to get above 130 F if you install 4 panels. If i were you i would go for much lower voltage drop ie 6awg to a combiner box on the roof and 4awg to the controller and batteries stay below 2% voltage drop (if not less to get the most from your system)
  • Hi,
    It would be best to provide more information. Make and model of panel, make and model of solar charge controller, and battery bank size in amp-hours.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
