Dakota98
Dec 15, 2014Explorer
jrnymn7 wrote:
The batteries will be stored outside in the cold. They will discharge very slowly. The OP prefers to run his generator than use solar...
...visit the rig every few weeks and do a quick top charge. Put the 'solar money' into fuel for the gennie.
The Genny is stored inside the TT & I forgot to mention, I keep the coach "covered" in the winter, accessing the generator would be a hassle. Also, that is the reason I don't wish to mount a panel on the roof as it would become useless. In my mind, I've already designed a tripod type of mounting system using 80 schedule PVC that will stand next to the coach & secured at the base with the panel @ about a 45 degree angle, pointed South.
CA Traveler: I looked at your son's set-up.... very nice. :)
smkettner: I don't know what I was thinking, You're right, with a 15 watt panel, I don't need a controller. :S
pianotuna: The Batts are 1-year old & for what I need to do, I'm reasonably sure a 15-30 watt panel will suffice. Remember also, the batteries will not have any load on them in storage.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
