Dakota98
Dec 15, 2014Explorer
jrnymn7 wrote:
On a 225Ah string, 1% per day, for 21 days, is only 47Ah; about 20% dod. Doing an 80-100% charge with a converter at 14.4v boost, then 13.6v normal, will only take 8-14 hours of gen run time; probably no more than the OP is use to doing on a daily basis, when dry camping. ;)
I don't use the genny in conjunction with the converter. The converter is a Magnetek & useless. I have a volt meter in the coach & when it hits 12.2, I use the genny with a portable smart charger & generally 3-4 hrs a day while dry camping. They are brought back to 100% charge after I get home.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
