BFL13
Dec 15, 2014Explorer II
pianotuna wrote:
Hi,
If you insist on going portable, do the 2 70 watt units and add a hinge. That way the two glass surfaces will be protected when storing the unit.
Really 140 watts is the bare minimum for 232 amp-hours of battery bank.
My panel instructions state that the white backing is just as delicate as the blue front, and do not prop it up using the white backing part, only use the frame.
Since the OP is only really intending to use his solar for storage, he can get the one panel and play with it when camping off grid-- if he ever does camp off grid. Once he ever does, he will become addicted to solar and then he can get more. No need to jump in at the deep end.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
