Johnny_G1's avatar
Johnny_G1
Solar Boost 2000E
Will the Solar Boost 2000E controller work with a 250 watt, 24 volt panel. a question for a friend after somebody climbed up on his mh and proceeded to jump on his 2 12 Volt Kyocera panels completely destroying them, he has a chance to buy some 24 volt panels but can' t afford to buy a new controller too. Thanks.
  • if you are talking about the Blue Sky 2000e
    yes it should, it will depend on the VOC 'open circuit voltage' of the panels
    they will need to wired parallel not series
    in series the total voltage will be too high, in parallel it should work
    the max voltage for the blue sky 2000e is 30v
    if the panels VOC is higher than that, he can not use those panels
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
