McKenziek wrote:
pianotuna wrote:
Hi,
I would not hesitate to buy those panels.
There are cheaper prices per watt--but those are for higher voltage panels requiring an MPPT controller to be used.
I was considering an MPPT from Morningstar. So, you're saying there is no need for MPPT with these panels? This is my first solar install and was trying to stay on budget under $1,000 so getting the PWM would save me some $$$. I have 2 pairs of T105's and plan to get 4 panels.
These are 36 cell panels, so a MPPT controller is not needed if you are running everything in parallel and a PWM would work just as well for less money.
The MPPT controller is required for higher voltage panels with more series cells or when making series panel connections.
