centerline
Feb 08, 2018Explorer
BFL13 wrote:
What 0.2 volts? Instead of staying at 13.8 all day on just converter it gets to 14.5 or so depending on how much sun gets on it (highly variable where the RV is). It can take all of the daylight hours to get there so it is above 13.8 all day.
Seems easier just to disconnect the solar at home than fiddle with the controller settings.
what solar controller do you have?
what you describe is also a symptom of a failed battery. are you absolutely certain the batteries test out ok?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
