curly5759's avatar
curly5759
Solar install on a Trailer, newbie questions
Hi, I just got a solar panel and controller for my TT. I want to install the panel on the roof laying flat but am unsure of how to attach it.
Q#1 Should I run some screws or bolts into the roof and seal, or ?? (It's a 07 Fleetwood Orbit 18' if that helps)
Q#2 How do I run the power cables inside, drill a hole in the roof, follow the roof antenna cable or ...?
Q#3 With the controller mounted inside, can I attach the charging cables to the power panel (+) and (-) or do I have to run another set of wires out front to the battery?
Q#4 Can I hook to shore power and leave the Solar connected?
Thanks for any and all help.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
