64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
DAS26miles wrote:
With all this high voltage of 14.8-15V aren't the refrigerators and furnace/thermostat in danger of frying the boards? I was told on the forum years ago to avoid using my generator with both my Intelli power 45amp converter charger and Xantrex 40amp battery charger together as the voltage exceeding 14.5 volts can fry the boards. Falsehood?
NinerBikes wrote:
That unit will lead you to believe that you need to buy more solar panels to get more charging amps to your battery, when it's the charge controller that's really messing up with your charging efficiency from your existing solar panel set up.
red31 wrote:NinerBikes wrote:
So you are getting 14.9V at the battery on a 60w panel, at 3.1 amps?
Not really, during bulk the amp meter is steady but in PWM the meter is erratic.
https://drive.google.com/file/d/0B-r-cHocscVWUXJBb1NRVVNDd2s/view?usp=sharing
