64thunderbolt
Jan 31, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
pianotuna wrote:
Hi,
One easy way to load up the system is to use an inverter. Connect a light bulb for a known load. Two or three sixty watt bulbs will do an excellent job.
DAS26miles wrote:64thunderbolt wrote:
I just went to Home Depot & bought #8 copper cable & made my own. It was a little tough getting the #8 into the lugs on the controller. I had a longer run than I should have due to the mounting location of the controller.
Did you buy black and red or was it two within the one wire? I see in the zoom at Renogy, the one I am interested in has 2 cables with the connectors and the second shorter leg has alligator battery clips and a inline fuse. I would need to make a 10-15 feet extension. Renogy doesn't make or carry an extension for that model, yet!
BFL13 wrote:64thunderbolt wrote:BFL13 wrote:
Your connection sequence is batteries to controller then array to controller. So you don't want to disconnect from batts with the array still on the controller. Covering the panel would be a good way to switch off solar. I put a switch on one of the wires from the panel close to the controller but my controller is easy to get at for that.
Useful if you are disconnecting the batteries for various reasons, you can turn off the solar first on the array side. Also with the array wire "open" you can measure Isc and Voc if you like.
Thanks for the instructions. Would it fry the controller if the sequence were reversed? I hooked it up in that fashion as the instructions said, batt first then panels. Just curious.
Maybe fry it. Might depend if it has a load on its load terminals but then no battery as well. They all want the batteries connected first to let the controller decide if it is going to be 12v or 24v battery before the array is connected. Since some controllers don't want array and no battery, IMO play it safe with yours if there is nothing mentioned about that in its manual.
