Lwiddis
Mar 14, 2020Nomad
Suitcase solar is a pain...set up, take down. Install a second panel on the roof. The panels should match each other. 100 watt panels may fit easier. Regarding whether that controller is adequate, add the max number of amps all the panels can produce and match to 80% or so of the controller’s max. 400 solar watts is usually the max for a 30 amp controller. Do some reading.
Two AMG batteries? For how much? Are they recently manufactured? What AH capacity?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
