Almot
Feb 23, 2014Explorer III
Keep in mind that most so called "flat" installations are slightly tilted, because it conforms to the roof slope. Unless your roof is totally flat - and in this case you'd better install the panel with slight slope, about 3 degrees, to drain the water and dust. This will help against snow accumulation as well. Lift one side (the one that is more likely to be the North side) about 3/4"-1" higher than the other side. Don't worry if the lifted side will become the South side at times - minus 3 degrees won't do much harm, and the other times it will work better than flat.
Landstar looks like a decent controller - it says "setpoints user defined" ? - if this is so, it's good.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
