Rbertalotto's avatar
Rbertalotto
Solar Panel Charge Issues..Trimetric 2025RV....HELP!
I thought this solar stuff would be easy........NOT!
I have a 120w Solar Cynergy Polycrystalline solar panel on the roof of my TC.....7' of #10 wire to the controller....18" of #10 wire to the shunt....12" #10 wire to the battery
I have one brand new 95AH Deep Cycle, Walmart (Johnson Controls) 12V battery....
I have a Phocos 20A controller....
My TC has a Centurion 3000 power converter , 1998 vintage...
I have a Trimetric 2025RV with a 500 Shunt....
Current Readings:
Volts ... 13.2
Amps .... -00.3
Percent Full... - - -
Settings:
P1 ...14.3
P2 ...02.
P3 ...090.
P4 ...A
P5 ...OFF
P6 ...OFF
P7 ...L1
My battery will only get to 13.2V and there it stays.
I have used a SEARS smart battery charger hooked up to it for a couple of days...13.2V..no more
http://www.sears.com/diehard-platinum-microprocessor-controlled-battery-charger-engine-starter/p-02871227000P?prdNo=11&blockNo=11&blockType=G11
I've left the Centurion 3000 on for days...Battery gets to 12.9 on a digital VOM and no higher
The solar panel is putting out 19- 27V over the course of the day (The camper is parked in a partially shaded area when not being used)
The Phocos is outputting only 12.8V no matter the output of the panel.
I have a feeling the Phocos is garbage.....Just a hunch. I want to replace it with a Morningstar Sunsaver 20A PWM
I have a feeling the SEARS charger is rubbish. I've ordered the Black and Decker VEC1093DBD as it is spoken of extremely highly on this and other forums.
I'm not sure I have the Trimetric set properly. ??? Why is "% Full" still showing three dashes?
What is the best way to monitor the solar panel output....Simple volt meter or a clamp on amp meter? When I park for best sun exposure, does it matter whether I'm monitoring Volts or Amps?
Looking at my system, how come my battery won't come up to 14+ volts as I see referenced in many posts and articles here on the internet.
Any help is greatly appreciated.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
