Almot
Apr 10, 2016Explorer III
Boon Docker wrote:
If your voltage reading was zero right from the solar panel (not after the charge controller) then your solar panel is defective.
... and if voltage is zero after the controller, then controller is defective or panel is not connected to correct terminals, or meter is not connected to correct terminals. Plenty of possibilities :)
One thing to remember is that controller should be connected to battery BEFORE connecting it to the panel, otherwise it could burn out.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
