red31
Apr 11, 2016Explorer
ozzie thousand oaks wrote:
Thanks Roy I went over to my camper at the yard and checked the voltage from the solar and of course it clouded up but I still checked it no volts i'll go back when its sunny you would think lance would sell you the correct panel for you're model camper
measure the voltage of the blue and white wires where they attach to the controller. The Blue is + and the white is -. The loop was to provide slack so the controller could be installed.
If you disconnect them and measure, you should see near 20v (18+) in almost any daytime light conditions.
You should be able to measure battery voltage at the controller, the wires that connect to the battery.
