red31
Apr 11, 2016Explorer
the zero voltage is aborant!
The OP should have his battery disconnect switch OFF in storage so there are NO parasite or other loads and the Lance panel is a trickle charger.
Unconnected, the panel wires should measure 20v, unconnected from the prewired roof connector the pigtail end should measure 20v, unconnected the blue/white at the controller should measure 20v.
The batt wires at the controller should measure batt voltage.
