Robert812 wrote:
Hi I think a question is in order. I'm installing a 80watt gopanel
with a 25amp reg. no where in the doc or what i found on the net is
what i'm looking for. why is their no off/on switch when coming from
the panel? I might be over thinking, but what if you wanted to change the battery or something else. I know it's only 80 watts and 26volts.
am I over shooting here. I have gave way to 12 volt batteries and installed (2)6volt. changed all my lights to leds(looks great) For just wanting to dabble in boondocking. thanks for viewing.
To service the battery: Disconnect the battery cables then one of the solar panel wires. If you add a switch or fuse you can use that item to break the connection. Reconnect the battery then the panel to controller when done. It is not that critical either way.
