alliemac9's avatar
alliemac9
Solar Panel Layout?
Me again....have questions on the best layout and mounting for the panels I bought.
Panels = 58.27" x 26.58" x 1.38" (26.4lbs)
Roof dimensions are roughly 100" wide by 251" long. This was my initial thought:
Proposed solar panel layout on a Class C RV. Drawing is to scale. The front of RV is at the top.
The line in front of the panels and behind the front vent demarcates the overhead cab; the roof slopes down to the front from that point forward. That is why I tried to fit the panels behind that line, so they were all on level roof. The distance from that line to the front of the roof is about 42 inches (i.e. shorter than the length of the panels).
However, I recognize the AC is taller and will have more shadow issues than the vent cover (all vents have covers). The clear space on either side of the AC is about 35", so just about 8" wider than the panels. It was recommended that I line the panels up in two straight rows and push them forward even though the front two panels will then straddle the break between the flat roof and the sloped roof. Does this look best? I don't know the angle of the slope, so I can't do the math to figure out the height differential and what impact it may have on my mounting options.
Any thoughts on this?
Here's a roof sketch with dimensions. We are planning to remove the antenna.
Roof dimensions. Not to scale (and not well proportioned).
  • It was suggested to me to use mounts that would raise the panels high enough so that shadows would not be an issue. Also, you do want some tilt to them to allow water to run off.
