pianotuna
Jan 19, 2016Nomad III
Hi Bob,
If you must mix and match I think a pwm controller would not get as "confused" as an MPPT unit. Accepting that premise means that voltage needs to be the same and wiring should be in parallel.
The insolaton to power curves seem quite similar.
Someone here had a poly and a mono. The mono would drop out when clouds passed by.
But, if I were going to add to my amorphous panels I'd pick poly. Or I'd start over with all poly.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
