ktmrfs's avatar
ktmrfs
Explorer III
Oct 12, 2013
solar panel output vs. tilt angle
I'm working on a pole mount for my portable panels so that when the trailer is in direct sun, or getting the panels 10' or so in the air gets good sun I can put them on the pole instead of on the ground.
What I have are two 80 watt panels.
The easiest mount would be to have the panels fixed and oriented perpendicular to the ground rather than at an adjustable angle. I know my panels do see higher current out at a 45-60 degree angle instead of flat on the ground, especially in the fall. Most of the time we will be 45 latitude or higher, so I think the ideal angle is near 60 degrees.
Anyone have any experience or info on how much difference in panel output I can expect between optimum and 90 degrees?
if it isn't much I'll likely not go through the effort to make adjustable angle mount.
With the mount scheme I have in mind it will be easy to rotate the panel to keep it facing the sun during the day when we are around the trailer.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
