Rail_Dawg's avatar
Rail_Dawg
Solar Panel positive/negative wire?
I can't remember and my google/owners manual search wasn't productive lol...
Is there a dedicated positive/negative wire on a solar panel or does it not matter how the wires go into the MPPT?
Thanks.
  • Thanks for the info guys.
    Will do exactly as you say.
    Glad I asked lol!
  • Yes it matters. They should be marked, but if not, put your multi-meter on voltage across the two wires with the panel facing the sun so there is some voltage.
    If you have pos to pos, the meter display will say, eg 34.2, but if you have neg to pos, the meter display will say - (minus) 34.2. So now you know which wire is which, put some red sticky tape on the panel's pos wire.
  • You must get polarity correct or the controller can be damaged.
    Trace them out and still check twice with a meter just before you connect.
    Controller to battery polarity is just as important. Also connect controller to battery before you connect the power from the panels.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
