jefffoxsr's avatar
jefffoxsr
Solar panel problem
I have used small solar panels for 15 years to keep batteries charged when toys are not use. I bought two new panels to hook up to other toys (motorcycles). These are just 2.5 watts. They have a built in controller even though one is not really needed for this application.
I fully charged both motorcycle batteries on the normal battery tender and then hooked up the solar panels for use while the bikes are in storage. I have done this in the past but I needed to use my other solar panels for a different use this time so that's why I bought new ones now.
Both of these panels seem to be pulling energy OUT of the batteries to the tune of 0.2 volts per day. The panels output the right amps and volts when hooked up to my multimeter but they are pulling juice out of the battery instead of putting juice in.
Today I rechecked the panels with the multimeter and they output correctly when in the sun in terms of volts and milliamps. I then hooked them up each to their respective motorcycle and aimed the panels at the bright sun. The voltage on the batteries actually goes down right away by .05 volts in .01 volt increments once you hook up the panels. It only takes about 5 seconds to go down .05 volts. When you turn the panel away from the sun or unhook the panels the voltage on the battery goes back up right away by .05 volts. This can be replicated multiple times. This makes no sense. This is the same on two separate motorcycles with two separate batteries and two separate solar panels that are brand new.
Why would this happen?
Thanks.
  • Sounds like you have your positives and negatives switched hooking up to the batteries. Is everything labeled well?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
