BFL13's avatar
BFL13
Explorer II
May 23, 2015
Solar-Panel to Controller Loss
Much has been made of the lower losses on the panel to controller path with MPPT because the amps are less. So once you have your loss measured, how valuable is it to improve on that if you don't like the loss amount you have?
EG, before I changed it all, I had a 1% loss on that path, but now I have a 2% loss. It can be reduced with a lot of bother, but is it worth it? Others with a similar problem might be interested in the calculations here.
At the time, the Vmp at the panel end was 29.0 and at the controller it is 28.5, so loss is 0.5/29 = 1.7% so with some work in my case this could be reduced to half that, say.
So what? Panel rated watts 255w. At Nominal Operating Cell Temperature (NCOT) of 45C (and today it came to 45C with the IR gun) and ambient 20C, you get a spec -0.43%/C drop in power for a total of 8.6% at NOCT so 8.6% of 255 is 22 so now you are down to 233w. Add line loss of 1.7% so now you are at ( 1.7% of 233 = 4w) so input to the controller is say 233-4 = 229w
Output from the controller was 215w at the time (12.7v x 17a) so loss in the controller is 229-215 = 14w/229 = 6%. (Reasonable mid-90s controller efficiency)
So what would the amps to the battery be if only that lousy 1.7% line loss on the panel to controller path could be cut in half?
Still starting at 233, now subtract 2 instead of 4w = 231w to controller with same 94% efficiency, loss is 13.86 instead of 14w Output is 217 instead of 215w
So with same batt v, you get 217/12.7 = 17.1a instead of 17a.
Hmmm. How much bother is worth 0.1 amp when you are already getting 17?
BTW, yes, I have a new 255w panel instead of the 230w panel for the 5er, and I will post some test results when the sky is right to allow testing someday soon. :)
  • One ampere hour lost per 10-hours at maximum potential? Ten ampere hours lost per hundred hours of max potential? One hundred amp hours lost per thousand?
    Perspectives in various time elements allows things to be seen in a different light - perhaps...
  • I think the question that should be asked at this point is, "are you getting enough power to your system everyday to satisfy your needs"? If yes, no need to do anything. If no, a 1% increase isn't going to improve things measurably. More or larger panels would be in order.
    Building from scratch I would shoot for 1 to 2%.
  • BFL13 wrote:
    JiminDenver wrote:
    It's all about balance BFL, what is it worth to you is what's important. 255w sounds like a Mono.
    It is a poly Canadian Solar (made in China) CS6P-255P with
    Vmp 30.2, Imp 8.43 and Voc 37.4, Isc 9.0
    I have it on the Eco-Worthy and they seem to be working well together. I need proper blue sky to do proper testing, whenever that happens.
    My 220w is a Canadian solar. I'll be interested in how it works out. I've seen the Eco-w's for $85 in auction on ebay.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    It's easy to calculate the loss, all you need to know is wire guage, wire length, and max current. Once you have the number, it's up to you to see if you want to improve.
    I agree with BFL, for a few % not really worth the effort and cost.
    And it is easy to do the process in reverse. Figure what loss you will live with, once you know the current and length, easy to determine minimum wire gauge to meet that loss. Keeps you from either (a) spending to much on to large wire or (b) redoing the whole wiring because you used way to small wire or way to long a run.
  • Unless I have an issue of poor performance that I believe can be improved I am not even taking the time to measure. Reason is for the exact reason BFL13 illustrates... lots of effort for little gain.
  • It's all about balance BFL, what is it worth to you is what's important. 255w sounds like a Mono.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
