Salvo wrote:
Careful when making a mppt to pwm comparison. Not only is mppt highly temperature dependent, but also battery voltage dependent. PWM can also be effected, but not as extreme.
For example, you got a mppt controller that outputs 100W. If battery voltage is 12.0V, charging current is:
I = P / V = 100V / 12.0V = 8.33A
If battery voltage rises to 14.0V, charging current is 7.14A, a 14.3% reduction.
Sal
The controller controls the rate of the battery's voltage change, and hence charge (input current).
Power delivered by the panel, and required by the batteries, will never be fixed and will be varied by the MPPT controller as needed so a fixed % analysis is moot.
As a side note, the MPPT controller is no more temperature dependent than the PWM controller and while you do get a larger change in voltage due to more series cells when using the higher voltage panels, the change in available power is nearly the same between panel types, so its really a wash...
