prairie_camper's avatar
May 04, 2018
Solar panel wiring
Has anybody ever heard of any 12 volt type solar panels not being able to wire them in series? Not physically of course but technically? I have 4 Coleman 100 watt panels and nowhere on the box or on the enclosed manual does it say to only wire in parallel or not to wire in series! Talked with a Coleman customer support rep, tech I think, and was told they can ONLY be wired in parallel??
I have been all over the Internet and cannot find anywhere, where there is some explicit instructions on any panel that I have seen to only wire them in parallel.
Now I am not looking for pros and cons over series vs. Parallel I am aware of all that. Just whether there are panels made that must be wired in parallel only?
__________________
  • It's not the panels, it's the controller.
    The issue is the PWM controller for 12v panels can only handle a low Voc like maybe 46 volts. Each panel has a Voc of 22v, so two in series is 44 (at 25C and higher when it is cold out.)
    If you are using an MPPT controller, it will have a Voc limit more like 100, so your four 22s in series is 88 and could be done.
    I have three 100s and have used them in parallel and in series. Got same amps to battery either way. I got the Isc value of 6.2 amps per panel in full high sun, so I was getting 18.6 amps with my PWM controller, panels in parallel.
    With four you could get 25 amps, so be sure to have at least a 30 amp controller (needs margin for times when panels get more than rated amps) whether you have a PWM or MPPT controller.
  • Panel needs bypass diodes to wire in series. Otherwise shade issues could burn out the panel.
    Call the tech back and see if it has a bypass diode. Or open the terminal box and see if they exist. Post a picture.
  • I am aware of all that...and that Coleman sells their name to anyone for anything. Therefore finding out anything about a “Coleman” panel manufacturered by the lowest bidder that week will be near impossible. Similar to the Garmin 660.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
