Golden_HVAC
Jun 06, 2015Explorer
30 watts is barely 2 amps at 15 volts (the charge rate while running from a solar panel).
If your CO meter is still on, that can use 0.8 amps per hour, 24/7. That can use more power than that tiny solar panel is collecting in the short winter months.
I would suggest a pair of 120 watt panels and a 20 amp charge controller.
SunElec.com sells a 140 watt panel for $229. At least one of these will save your battery all winter, if you can keep the snow off of it!
Fred.
Fred.
