Dakota98
Jun 06, 2015Explorer
mgfiest wrote:
I check the voltage at least 1 a month and it ranges from 12-13 volts, so it appears to be keeping it charged. I go and check the voltage on the battery and it still states 12 - volts.
Is there somehting missing in my charging?
Yes, & I suspect the battery is shot. Check the water levels, check SG, & attempt charging it with a portable smart charger. Or you can take is somewhere & have it tested.
Take the above advice concerning Solar charging.
