EsoxLucius wrote:
scroller95969, you are right the TS-MPPT-45 is rated for 1200 watts maximum solar array input at 24 volts and two 300 watt 24 volt panels would provide only half of that. The MPPT controller will convert nominal 24 volts (actually up to 40 volts with some panels) from the panel array to accommodate an RV nominal 12 volt system. Even at nominal 12 volts the maximum PV array input rating is 800 watts when using Normal Operating Cell Temperature ratings which is more like real world conditions than the standard test.
Batteries do not provide input power to a solar charge controller, the PV panel array does.
This is confusing. Let's try another approach: From the MS manual.
TS-MPPT-45 TS-MPPT-60
Maximum Battery Current 45 Amps 60 Amps
12 Volt 600 Watts 800 Watts
24 Volt 1200 Watts 1600 Watts
48 Volt 2400 Watts 3200 Watts
The above voltages are for the battery bank and have absolutely nothing to do with so called 12V or 24V panels.
For the typical 12V RV the maximum array wattage is 600W for the MPPT 45. You can use 1200W if and only if you have a 24V battery bank which is rare for a RV.
You can use whatever voltage panel array desired as long as you don't exceed the 150V maximum array voltage input.
