Empty_Nest__Soo's avatar
Jun 03, 2015
Solar panels for less than ideal conditions - bypass diodes?
I’m looking at adding solar capacity to the coach. For boondocking, we figure to be in an area where overcast, clouds, some shade, etc. are common. I want to choose panels that will perform as well as possible under less than ideal conditions.
I’ve done a lot of reading and one important factor seems to be bypass diodes. I believe understand their role in preventing a shaded cell from killing output from the entire panel. It seems that more diodes are better than fewer in regard to performance in less than ideal conditions.
I’m looking at nominal 12-volt panels. These seem to all be 4 rows of 9 cells.
In looking at the specs for various panels, I almost never see specified the number of bypass diodes. Are nominal 12-volt panels universally fit out with 3 bypass diodes, one between each row of cells? Or, are some 12-volt panels made with more bypass diodes, and therefore figure to be less affected by partial shading?
Wayne
  • Are you going in series? If not the bypass diodes are not going to matter much. Lose one row and there is not enough voltage to charge the battery.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
