I have 2 65w panels connected through a controller. I am testing them with the connection wires disconnected. I am getting 20.5 VOC and 3.5 ISC from each panel. The back of each panel says it shoul...
SoCal? Sun is a bit low in the sky this time of year so less energy available. Are the panels mounted flat on the roof or facing direct at the sun? As said above the measurements sound normal. Check it again in June pointed direct at the sun.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
