Slownsy's avatar
Slownsy
Solar panels
I have 4/150W Renogy panels RNG-150D
P max150W
V of 22.5V
I sc 9.05A
V mp 8.38A
Max system Voltage 600VDC (UL)
Max Fuse Rating 15A
Can someone please walk me true the meaning of the individual ratings meaning.
I understand that they are 150W 12V . What does the 600VDC particularly mean, I guess it has to do with how many panels can be joined?
Thanks Frank.
  • 2oldman is correct.
    https://www.altestore.com/blog/2016/04/how-do-i-read-specifications-of-my-solar-panel/#.YF1XItxME2w
    Open Circuit Voltage (Voc)
    Open circuit voltage is how many volts the solar panel outputs with no load on it. If you just measure with a voltmeter across the plus and minus leads, you will read Voc. Since the solar panel isn’t connected to anything, there is no load on it, and it is producing no current.
    Maximum Power Point (Pmax)
    The Pmax is the sweet spot of the solar panel power output, located at the “knee” of the curves in the graph above. It is where the combination of the volts and amps results in the highest wattage (Volts x Amps = Watts).
    V of 22.5V nominal voltage of the panel--probably best to use MPPT controller with this. If the controller can tolerate a 45 volt input, I'd wire in series/parallel.
    Isc short circuit current.
  • Yes, it means the max voltage if connected in series. As least that's what I think it means. Only the last panel of about 35 in the string would reach that.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
