I have a Winnebago Voyage 2006 with a 10w solar panel. I was thinking of a 100w panel. Would it be easy to install with the existing system? What are solar panels like for dry camping in shaded areas?...
That 10 watt panel on the roof of a large motor-home is doing nothing. The amperage drop over the length of the wire alone makes it useless. You might be able to use the existing wire to pull new, larger wire.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
