I have a factory installed 100 watt solar panel on my Artic Fox fifth wheel and would like to add another 100 watt panel. The manufacture tell me the solar charger will handle another 100 watt panel. ...
MC4 connectors are designed for series connections. To use MC4 connectors in parallel, you need to buy a pair of Multibranch MC4 adapters and you need of course to have MC4 connectors on both panels. I think MC4 are soldered on the cable, so you have to either solder or crimp it somehow (after buying all the connectors and adapters).
Other than VERY rarely needed ability to quickly disconnect and re-connect the panels, I don't see any benefits in getting MC4 if you don't have it already.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
