MEXICOWANDERER
Nov 15, 2017Explorer
One single cable to the battery positive post or posts and one single connection to the battery negative post. Trailer breakaway can be wire + to the bussbar and - to the battery side of the negative side disconnect switch.
https://www.ebay.com/itm/7-Point-3-Small-4-Large-3-8-Power-Distribution-Block-Red-DC-Bus-Bar-Insulated/291907136543?hash=item43f7056c1f:g:oXUAAOSwYIxX~ORp&vxp=mtr
Multiple connection points, to accomodate multiple power connections
Nickel Plated Brass contact plate: high current & anti-corrosive
Max Amperage:
250 amps @ 12 vdc per connection (large post sizes)
* Max Voltage: 48 vdc
5/16", 3/8", M8 or M10 stainless steel connection posts
Stainless steel hex nuts and washers
Base Material: 16% Glass-Filled Nylon (Red & Black)
Mounting screws: #10 (not included)
Mounting center: 5.7 in
Model with cover includes appropriate cover and retaining nuts
CUSTOM FIT BATTERY CABLES
http://www.genuinedealz.com/custom-cables/custom-battery-cable-assembly
Max Amperage:
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
