centerline
Nov 15, 2017Explorer
you can connect all the outgoing wires to one positve post and one negative post, and all the incoming wires from the chargers to the opposite pos and neg posts...
the batteries wired parallel will be fine this way and keep the posts organized...
just make sure each "pair" of wires are connected to the posts of opposite batteries, and not to the posts of the same battery.
as for the solar array of 4 130w panels, 2 batts will work without any problem, but 3 or 4 12v batts would allow you to get the most from the system... you are being short changed on your investment having only two batteries with that many potential amps...
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
