allen8106
Nov 16, 2017Explorer
2oldman wrote:
OP.. what about the negative post?
The negative battery post only gets one cable. This cable goes to the shunt. All other negative cables hook to the other side of the shunt. At this point there's only the negative battery cable from the charge controller and the negative battery sense wire from the charge controller.
On the positive side of the battery there is the following:
1) Charge controller positive battery cable.
2) OEM converter positive cable.
3) Battery monitor positive wire.
4) Charge controller temperature sensor.
5) Inverter temperature sensor.
6) Charge controller positive sense wire.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
