MEXICOWANDERER
Nov 16, 2017Explorer
The most reliable connection to a car car RV battery that would see high amperage discharges is this...
And inter-tie with this...
Both positive and chassis negative battery posts
This place can custom fabricate and ship to you...
http://www.genuinedealz.com/custom-cables/custom-battery-cable-assembly
After seeing innumerable studs de-soldered from RV terminals due to high inverter ampere loading, I am dead-set against using the Gyro-Gearloose wing nut and stud. A plated steel nut and external tooth star washer binds a ring terminal to a top stud reasonably well. Counterforce rotation stress during tightening. Water pump pliers or even a large crescent wrench would work. Beware of shorting the tool against chassis metal. Remember NEGATIVE is FIRST OFF and LAST ON.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
