allen8106
Nov 18, 2017Explorer
So what I ended up doing was fabricating a short "Shunt" to allow two more connection points out of copper tubing. I attached the inverter positive cable, inverter temperature sensor and charge controller temperature sensor to the main battery post. The other connections were split between the two connection points on the copper "shunt".
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
