grizzzman
Nov 10, 2016Explorer
TxGregory wrote:
***Link Removed***Hello, I recently purchased a 2006 Thor Wanderer 30' travel trailer. I was disappointed that I could only run my cpap machine when the trailer is plugged in. I also dislike rv parks, and I really want to spend my time elsewhere, and preferably not plugged in all the time. I am going to put two 100 W solar panels on top. They come with a mounting kit and a charge controller. I thought about just hooking them up to charge the battery, but that doesn't do much for me, because I still can't run my cpap when I am not plugged in. So I was thinking of connecting them to a second deep cycle battery (I have a place for it up front), then using the second deep cycle battery to power an inverter that I would plug into the 30 amp plug that would normally go to external power. My wife also has a cpap, and we like to spend time on our laptops. I put together a picture of what I was thinking. I need some help from someone proficient in electronics to advise me on this. I don't have a lot of money, and I am not physically able to do crawl around the insides of the trailer reconfiguring things. So I came up with this, hoping that it would not all blow up! I am unsure of the size of inverter I need. I would like to just put a 3000W one on, but they are expensive. The 1000W inverter was much cheaper. Also, I am wondering if I need three panels. I am guessing that 3 panels and a 3000W inverter, on a sunny day, would allow me to run everything just as if I was plugged into power. But I don't want to spend that kind of money if I can avoid it.
Thank you in advance,
Can you make this work? Well yes,but you need to understand better what you are doing. May I suggest a little homework? The 12 volt side of life part 1 (Please read part 2 to.
You lack info that is needed to assist in achieving your goal. If you read this you will understand.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
