My 2023 Cherokee Wolf Pup 22RR has a factory installed solar panel. Realistically speaking, can the trailer be used with the single battery installed without it dying? I am thinking of installing a...
The introduction of Lithium RV batteries made battery powered AC possible for short periods if you have the space for mounting them. However, recharging those batteries from solar just isn’t practical unless most of your roof is covered with panels and you are in good direct light. Since OP is in Ontario, not likely. With ten 100 watt panels putting out 50 amps…that’s six hours to recharge 300 or so AHs, and you’ll just not get that.
