swimmer_spe
Oct 28, 2022Explorer
Solar power
My 2023 Cherokee Wolf Pup 22RR has a factory installed solar panel. Realistically speaking, can the trailer be used with the single battery installed without it dying? I am thinking of installing a...
time2roll wrote:swimmer_spe wrote:Unplug and check what works.
OP here.
Many of you are posting without knowing what my trailer is equipped with. The questions about the battery, panel and other electrical questions do not help. I am not looking for someone to do math. I can do that.I am looking for someone who has one and knows what it can and cannot do.
Fridge should work best on propane. (Probably has 12v controls and ignition)
Lights will work. Maybe not the ceiling fan
Water pump works
Water heater should work on propane. (probably has 12v controls and ignition)
Electric front jack should work. Possibly the leveling jacks.
Furnace should work burning propane. Has 12v fan and electronic ignition.
Cooktop and oven should work on propane.
No microwave
No air conditioning
No electric water heat
No electric outlets
What did I mis?
